Ana içeriğe geç
Dell Latitude D630 Battery Replacement
  1. Dell Latitude D630 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Battery Replacement: adım 2, 1 resimden 1.
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
Sonuç
To install your new battery, follow the steps in reverse order and slide your new battery in.
12 farklı kişi bu kılavuzu tamamladı.
Justin Ng
142 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 üyesi
CPSU-JOHANN-W13S6G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 9,355
