Ana içeriğe geç
Dell Latitude D630 CMOS Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude D630 CMOS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 CMOS Battery Replacement, Keyboard: adım 3, 3 resimden 1. Dell Latitude D630 CMOS Battery Replacement, Keyboard: adım 3, 3 resimden 2. Dell Latitude D630 CMOS Battery Replacement, Keyboard: adım 3, 3 resimden 3.
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Dell Latitude D630 CMOS Battery Replacement: adım 4, 1 resimden 1.
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Dell Latitude D630 CMOS Battery Replacement: adım 5, 2 resimden 1. Dell Latitude D630 CMOS Battery Replacement: adım 5, 2 resimden 2.
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Dell Latitude D630 CMOS Battery Replacement: adım 6, 2 resimden 1. Dell Latitude D630 CMOS Battery Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
  7. Dell Latitude D630 CMOS Battery Replacement, CMOS Battery: adım 7, 1 resimden 1.
    • Remove the connector to the coin using the spudger.
    • Slide the coin battery out of its slot by wiggling its connector with a gentle tug.
    • You may also need to use the spudger to carefully push out the battery from the top of the slot where the yellow square is.
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
Jon Amireh
1.698 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 üyesi
CPSU-JOHANN-W13S6G1
4 Üyeler
10 adet Kılavuz yazıldı
9 Yorum
off topic but...in step 4, what is the component plugged into the white cable at the top left hand corner right above that screw?
Josh Henderson - Yanıt
That looks like the Bluetooth module @Josh Henderson
stm reusables -
I love the easy-to-fix design of these older Dell Latitudes!
Joseph Sctbunio - Yanıt
Worst CMOS battery placement I have seen. PPD
Lewis Balentine - Yanıt
it is proving a lot harder to get the battery back in place than to remove it. More photos and guidence would be a helpful.
chefkevin1uk - Yanıt
One question. Since the battery is nowhere near the keyboard cable, could you just prop the keyboard up so it’s out of your way and then replace the battery? Also, how is the black plastic surrounding the battery connected to the laptop? Would it make it easier to replace if you removed that first?
Patrick Dickey - Yanıt
good instructions thanks!, “how is the black plastic surrounding the battery connected to the laptop ? “
its flexible, just lift it up and pull battery under it.
Pete K - Yanıt
What SIZE battery?
Jessica - Yanıt
Best explanation I saw. Simple and professional. Thank you.
Geo70 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 117
Her zaman: 49,823
