Ana içeriğe geç
Dell Latitude D630 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Latitude D630 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Dell Latitude D630 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Dell Latitude D630 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: adım 5, 2 resimden 1. Dell Latitude D630 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Savi Chavan
979 İtibar
1 Kılavuz yazıldı
Ekip
4 Yorum
Dell latitude 2RHczd1
C Chandler - Yanıt
Thank You Sir !
Bartłomiej Be - Yanıt
I appreciate the guide my good sir. Very helpful.
Matt Erti - Yanıt
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 15,694
