Ana içeriğe geç
Dell Latitude D630 Keyboard Replacement
Neye ihtiyacın var
    1. Dell Latitude D630 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
      • Turn the laptop over so its bottom is facing you.
      • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude D630 Keyboard Replacement: adım 2, 1 resimden 1.
      • Using two index fingers, slide the battery latches outward.
      • While still holding the latches out, use your thumbs to slide the battery out towards you.
      • Once the battery is dislodged, you can let go of the latches and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Latitude D630 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Dell Latitude D630 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Dell Latitude D630 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
      • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
      • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
      • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude D630 Keyboard Replacement: adım 4, 1 resimden 1.
      • Remove the three 3mm Phillips #0 screws securing the keyboard.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Latitude D630 Keyboard Replacement: adım 5, 2 resimden 1. Dell Latitude D630 Keyboard Replacement: adım 5, 2 resimden 2.
      • Slowly bring the keyboard up and fold it back onto the touchpad.
      • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Latitude D630 Keyboard Replacement: adım 6, 2 resimden 1. Dell Latitude D630 Keyboard Replacement: adım 6, 2 resimden 2.
      • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
      • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Jon Amireh
1.746 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 üyesi
CPSU-JOHANN-W13S6G1
4 Üyeler
83 adet Kılavuz yazıldı
3Kılavuz Yorumları
These instructions were A+ fantastic! I have NEVER done any kind of computer dis-assembly OR re-assembly before. Your directions and pictures helped me feel confident from start to finish with a 100% success on the first try. I bought my son a Dell 630 to play Minecraft on and it needed a new keyboard, so THANK YOU, THANK YOU for making it possible for me do this so flawlessly. :-)
Tamara
Tamara - Yanıt Paylaş
Good job, easy to follow instructions without being over the top, good quality photos
Gordon McIntosh - Yanıt Paylaş
THIS I like !!! Finally, a series of shown steps that most anyone with brain can understand and do. My keyboard is worn out, there are wear holes in several keys.... yea, it is time to replace it and .... NOW WE CAN !
Warren
Warren Sjoberg - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 57
Her zaman: 8,556
