Ana içeriğe geç
Dell Latitude D630 RAM (Slot B) Replacement
Neye ihtiyacın var
    1. Dell Latitude D630 RAM (Slot B) Replacement, Battery: adım 1, 1 resimden 1.
      • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
      • Turn the laptop over so its bottom is facing you.
      • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude D630 RAM (Slot B) Replacement: adım 2, 1 resimden 1.
      • Using two index fingers, slide the battery latches outward.
      • While still holding the latches out, use your thumbs to slide the battery out towards you.
      • Once the battery is dislodged, you can let go of the latches and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Latitude D630 RAM (Slot B) Replacement, RAM (Slot B): adım 3, 1 resimden 1.
      • Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude D630 RAM (Slot B) Replacement: adım 4, 1 resimden 1.
      • Use your fingers to push out the latches holding the RAM in place.
      • The RAM should now sit up at an angle so you can safely remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To install the new RAM, set it in the slot at an angle and push it in until the latches reclick.
14 farklı kişi bu kılavuzu tamamladı.
Jon Amireh
1.746 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 üyesi
CPSU-JOHANN-W13S6G1
4 Üyeler
83 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 6,570
