Ana içeriğe geç
Dell Latitude D820 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Latitude D820 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the charger from the laptop.
    • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
    • If you are replacing other components, leave the battery out.
    • If you are only replacing the battery, reverse the steps to install a new battery.
  2. Dell Latitude D820 Hard Drive Replacement, Hard Drive: adım 2, 2 resimden 1. Dell Latitude D820 Hard Drive Replacement, Hard Drive: adım 2, 2 resimden 2.
    • Locate the hard drive compartment in the lower right hand corner of the bottom of the laptop. It is located next to the empty battery compartment. The words 'Strike Zone' are engraved on it.
    • Locate and remove three philips head screws. These screws measure 3.55mm in length and 2.93mm in width with a fine thread.
    • Gently slide grip pad to the right and the hard drive should slide out.
    • Reverse the process to install new hard drive.
Sonuç
Removing and replacing the hard drive
2 farklı kişi bu kılavuzu tamamladı.
Elizabeth
423 İtibar
2 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 1-2, Prince Fall 2014 Pasco Hernando, Team 1-2, Prince Fall 2014 üyesi
PHSC-PRINCE-F14S1G2
10 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
You also need to unscrew the grip pad from the old hd and screw it onto the new one.
Sue - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 3,423
