Ana içeriğe geç
Dell Latitude D820 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Latitude D820 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the charger from the laptop.
    • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
    • If you are replacing other components, leave the battery out.
    • If you are only replacing the battery, reverse the steps to install a new battery.
  2. Dell Latitude D820 Keyboard Replacement, Keyboard: adım 2, 3 resimden 1. Dell Latitude D820 Keyboard Replacement, Keyboard: adım 2, 3 resimden 2. Dell Latitude D820 Keyboard Replacement, Keyboard: adım 2, 3 resimden 3.
    • Open laptop lid and extend screen until it is parallel with the keyboard.
    • Locate the notch in the upper right corner of the keyboard (just above the 'page up' button).
    • Insert the plastic spudger and very gently lift the faceplate. It will make a soft snapping sound.
    • Set aside.
  3. Dell Latitude D820 Keyboard Replacement: adım 3, 1 resimden 1.
    • Locate the three philips head screws above the keyboard. One is above the 'Pause/Break' key; one above the F7 key and one above the 'Esc' key. Remove all three.
  4. Dell Latitude D820 Keyboard Replacement: adım 4, 1 resimden 1.
    • Gently lift top of keyboard and lay forward on palm rest.
    • Locate blue pull tab and gently disconnect ribbon cable from motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Michael Coleman
162 İtibar
1 Kılavuz yazıldı
Ekip
Pasco Hernando, Team 1-2, Prince Fall 2014 Pasco Hernando, Team 1-2, Prince Fall 2014 üyesi
PHSC-PRINCE-F14S1G2
10 Üyeler
7 adet Kılavuz yazıldı
4Kılavuz Yorumları
I am the author of a high-altitude cookbook. I self-publish. My "A" key decided to stop working on my dell XP, and then the internet would not connect. When I finally purchased a new computer Windows 8, I discovered I could not format it for my hp business injet 2300. This printer is a duplexer, and key to my cookbook business. The other problem was Quark Express 6.1 would not work on it. Two thousand plus seemed a little high for a new Quark. After fiddling around with the internal keyboard and using the "copy and replace function" I decided on a new keyboard. Found a new one on ebay cheap. The instructions here were a blessing. Thank you, thank you, thank you! I now have my XP back working like new. The Windows 8 can be for the internet,
DAWN KLEIN - Yanıt
Thank you very much. I am glad it helped and your back up and running. Just a side note: Be careful using Windows XP on the Internet these days, since it no longer receives security updates from Microsoft. Thanks again!
Henry -
You gave great directions. I never reassembled something I took apart. Worked like a charm Thanks so much!!!
Cheryl Baynard - Yanıt
Beautifully clear - perfect! Thank you.
David Harmsworth - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 2,221
