Giriş
If you have had your computer for 10-20 years or if your laptop has been having issues with blue crash screens, slower processing speeds, or not recognizing hardware. Then you need to replace your motherboard. Follow this guide will show how to replace the motherboard step by step.
Before beginning make sure you backup all important data files on the system onto an external memory device (A Hard Drive or USB)
Neye ihtiyacın var
Perform a complete system backup and shutdown the computer.
Unplug the charger and remove the battery.
Remove the battery by sliding the lock tab and use your other hand to remove the battery.
14 farklı kişi bu kılavuzu tamamladı.
2 Yorum
i used this to replace the thermal paste its really easy to follow simple steps
