Ana içeriğe geç
Dell Latitude D830 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Latitude D830 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Orient the laptop so that the back is facing you.
    • With a phillip's head screwdriver, remove the two screws on the back corners of the laptop.
  2. Dell Latitude D830 Keyboard Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over, with the opening still facing up.
    • With a phillip's head screwdriver remove the two screws in the upper two corners.
  3. Dell Latitude D830 Keyboard Replacement: adım 3, 1 resimden 1.
    • Open the laptop up. Displaying the keyboard and screen.
    • Take a spudger and insert it under the left edge of the panel between the keyboard and screen.
    • Use the spudger to pry under the panel.
  4. Dell Latitude D830 Keyboard Replacement: adım 4, 1 resimden 1.
    • Place the spudger under the middle of the panel and use it to pry the panel off.
  5. Dell Latitude D830 Keyboard Replacement: adım 5, 1 resimden 1.
    • Place the spudger under the right side of the panel and use it to pry the panel off.
    • For additional help the spudger can be placed around the edge of the panel and used to pry it off.
  6. Dell Latitude D830 Keyboard Replacement: adım 6, 1 resimden 1.
    • After you have the panel popped out, then you must pull the screen up as shows in the picture.
  7. Dell Latitude D830 Keyboard Replacement: adım 7, 1 resimden 1.
    • The screen will only be connected by the wiring.
    • Take the screen and gently place it on the table as shown in the picture.
    • Now you must remove the three screws highlighted in the picture.
  8. Dell Latitude D830 Keyboard Replacement: adım 8, 1 resimden 1.
    • After removing the three screws, slide the keyboard out so the mainframe of it is loose.
    • The a component still attached at the bottom.
  9. Dell Latitude D830 Keyboard Replacement: adım 9, 1 resimden 1.
    • The highlighted item should be the only component holding the keyboard on.
  10. Dell Latitude D830 Keyboard Replacement: adım 10, 1 resimden 1.
    • Where the rectangle is, there is a silver lever that you must push back.
    • Then where the circle is on the photo, you must take the spudger and push in.
    • This will then pop the white clip off and the keyboard will be free.
  11. Dell Latitude D830 Keyboard Replacement: adım 11, 1 resimden 1.
    • The keyboard is now completely detached, and is ready to be replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 816
