Ana içeriğe geç
Dell Latitude E4200 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: adım 1, 1 resimden 1.
    • Open computer.
  2. Dell Latitude E4200 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
    • A small flat head screwdriver would be an ideal tool to use during this step.
  3. Dell Latitude E4200 Keyboard Replacement: adım 3, 1 resimden 1.
    • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
  4. Dell Latitude E4200 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Use a PH00 screwdriver to unscrew the screw.
  5. Dell Latitude E4200 Keyboard Replacement: adım 5, 2 resimden 1. Dell Latitude E4200 Keyboard Replacement: adım 5, 2 resimden 2.
    • Use your hands to gently lift the keyboard from the device.
  6. Dell Latitude E4200 Keyboard Replacement: adım 6, 1 resimden 1.
    • Gently turn the keyboard over.
  7. Dell Latitude E4200 Keyboard Replacement: adım 7, 1 resimden 1.
    • Be careful not to disconnect the keyboard connector.
  8. Dell Latitude E4200 Keyboard Replacement: adım 8, 1 resimden 1.
    • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
  9. Dell Latitude E4200 Keyboard Replacement: adım 9, 1 resimden 1.
    • Completely lift the keyboard from the device, as they are now disassembled.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michelina Carbone
197 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 5-6, Williams Spring 2015 Baylor, Team 5-6, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 4,294
