Ana içeriğe geç
Dell Latitude E4200 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude E4200 RAM Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 RAM Replacement: adım 2, 3 resimden 1. Dell Latitude E4200 RAM Replacement: adım 2, 3 resimden 2. Dell Latitude E4200 RAM Replacement: adım 2, 3 resimden 3.
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 RAM Replacement: adım 3, 1 resimden 1.
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 RAM Replacement, Remove the back panel: adım 4, 1 resimden 1.
    • Once you removed the back panel, the RAM will easily be located.
    • Be sure to remove the battery first
  5. Dell Latitude E4200 RAM Replacement, Take out the RAM: adım 5, 2 resimden 1. Dell Latitude E4200 RAM Replacement, Take out the RAM: adım 5, 2 resimden 2.
    • Place your thumbs on each side of the RAM tabs.
    • Gently push outward on the tabs to release the RAM. This will allow you to remove the RAM completely from your device.
    • The RAM should "bump up" after you push away the tabs.
  6. Dell Latitude E4200 RAM Replacement: adım 6, 3 resimden 1. Dell Latitude E4200 RAM Replacement: adım 6, 3 resimden 2. Dell Latitude E4200 RAM Replacement: adım 6, 3 resimden 3.
    • Gently grab each side of the RAM and remove it from the device.
    • Please do not touch connection side of the RAM (shown in orange) with fingers. It might causes possible corrosion to the connection.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chao Wei
128 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 5-6, Williams Spring 2015 Baylor, Team 5-6, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 2,639
