Ana içeriğe geç
Dell Latitude E4200 SSD Replacement
Neye ihtiyacın var
  1. Dell Latitude E4200 SSD Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 SSD Replacement: adım 2, 3 resimden 1. Dell Latitude E4200 SSD Replacement: adım 2, 3 resimden 2. Dell Latitude E4200 SSD Replacement: adım 2, 3 resimden 3.
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 SSD Replacement: adım 3, 1 resimden 1.
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 SSD Replacement, SSD: adım 4, 1 resimden 1.
    • Unscrew the two 4.10x4.05 mm screws holding the SSD in place.
  5. Dell Latitude E4200 SSD Replacement: adım 5, 1 resimden 1.
    • Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
  6. Dell Latitude E4200 SSD Replacement: adım 6, 1 resimden 1.
    • By applying pressure to the sides of the connector, pull the connector apart from the SSD.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
John Shellenberger
490 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-6, Williams Spring 2015 Baylor, Team 5-6, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G6
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/166263029472
jacques_06 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 8,353
