Giriş
The CPU cooling fan is used to cool down the Dell Latitude E4300's central processing unit. The CPU is an electronic circuitry that carries out the computer's programs. There are some occasions in which the fan can collect dust or break down. When this occurs, the CPU will not receive the cooling it needs and your laptop will begin to overheat. If you are having a constant issue with overheating, try following this guide to replace your cooling fan.
Neye ihtiyacın var
With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
Be aware there are two deeply recessed screws on both sides to the rear of this panel. There are also two screws externally on the rear face either side of the battery that hold the monitor on and pass through this panel, support the screen when you remove these. There are also two screws above the hard drive bay that need to be removed.
Using a Phillips 1 Screwdriver, remove the two M2.5x5-mm screws located on opposite sides of the fan.
Bir başkası bu kılavuzu tamamladı.
