Giriş
Is your laptop out of storage or not reading files correctly? Consider using this guide to replace the hard drive of your laptop.
Parçalar
Hiçbir parçaya gerek yok.
  1. Open the laptop and remove the small panel located above the keyboard.
    • Open the laptop and remove the small panel located above the keyboard.
  2. Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Pull off keyboard forward and then outwards.
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
  6. Remove additional wires located within the panel. For the smaller wires, try using a spudger for easier access.
    • Remove additional wires located within the panel.
    • For the smaller wires, try using a spudger for easier access.
  7. Lift the keyboard panel to separate the component from the rest of the device.
    • Lift the keyboard panel to separate the component from the rest of the device.
  8. Unscrew the three screws located on the top of the component. Lift the hard drive out of its holding in an outward motion and remove it from the device.
    • Unscrew the three screws located on the top of the component.
    • Lift the hard drive out of its holding in an outward motion and remove it from the device.
Sonuç
Ryan Blakey
172 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
What!?! You can simple remove the hard drive by undoing two screws on the bottom of the laptop. Then you can remove the bezel from the laptop by undoing one more screw. It’s detailed in the service manual on the Dell website.
Rob Walter - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 10
Son 30 Gün: 18
Her zaman: 76
