Ana içeriğe geç
Dell Latitude E4310 Display Replacement
Neye ihtiyacın var
  1. Dell Latitude E4310 Display Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop and remove all power cords.
  2. Dell Latitude E4310 Display Replacement: adım 2, 2 resimden 1. Dell Latitude E4310 Display Replacement: adım 2, 2 resimden 2.
    • Push in the battery release button with your thumb.
    • Pull up on the battery to remove.
  3. Dell Latitude E4310 Display Replacement, Display: adım 3, 3 resimden 1. Dell Latitude E4310 Display Replacement, Display: adım 3, 3 resimden 2. Dell Latitude E4310 Display Replacement, Display: adım 3, 3 resimden 3.
    • Open up the laptop and flatten it down on a workable surface.
    • Turn it around so that the screen is closest to you.
    • Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
    • Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
    • Remove the bezel.
  4. Dell Latitude E4310 Display Replacement: adım 4, 2 resimden 1. Dell Latitude E4310 Display Replacement: adım 4, 2 resimden 2.
    • Remove the six 0.3mm Phillips #1 screws.
  5. Dell Latitude E4310 Display Replacement: adım 5, 2 resimden 1. Dell Latitude E4310 Display Replacement: adım 5, 2 resimden 2.
    • Remove the two 0.5mm Phillips #1 screws.
    • There are two screws located at each corner. Only remove the ones closest to the outer edge.
  6. Dell Latitude E4310 Display Replacement: adım 6, 2 resimden 1. Dell Latitude E4310 Display Replacement: adım 6, 2 resimden 2.
    • Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
  7. Dell Latitude E4310 Display Replacement: adım 7, 3 resimden 1. Dell Latitude E4310 Display Replacement: adım 7, 3 resimden 2. Dell Latitude E4310 Display Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to flip the blue tape 180 degrees.
    • By flipping the tape you disconnect the display connector.
  8. Dell Latitude E4310 Display Replacement: adım 8, 1 resimden 1.
    • Remove the screen from the laptop.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,529
