Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Push in the battery release button with your thumb.
Pull up on the battery to remove.
Open up the laptop and flatten it down on a workable surface.
Turn it around so that the screen is closest to you.
Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
Remove the bezel.
Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
Use a pair of tweezers to flip the blue tape 180 degrees.
5 farklı kişi bu kılavuzu tamamladı.
