Ana içeriğe geç
Dell Latitude E4310 MiniCard Replacement
Neye ihtiyacın var
  1. Dell Latitude E4310 MiniCard Replacement, Mini Card Door: adım 1, 3 resimden 1. Dell Latitude E4310 MiniCard Replacement, Mini Card Door: adım 1, 3 resimden 2. Dell Latitude E4310 MiniCard Replacement, Mini Card Door: adım 1, 3 resimden 3.
    • Remove the single Phillips #1 screw.
    • This screw will not necessarily come off of the panel.
    • Lift up and remove with your fingernail, or a spudger, from the side of the door with the screw.
  2. Dell Latitude E4310 MiniCard Replacement, MiniCard: adım 2, 1 resimden 1.
  3. Dell Latitude E4310 MiniCard Replacement: adım 3, 3 resimden 1. Dell Latitude E4310 MiniCard Replacement: adım 3, 3 resimden 2. Dell Latitude E4310 MiniCard Replacement: adım 3, 3 resimden 3.
    • Use a spudger to pry up the card.
    • Pull the card up and out of its slot.
  4. Dell Latitude E4310 MiniCard Replacement: adım 4, 3 resimden 1. Dell Latitude E4310 MiniCard Replacement: adım 4, 3 resimden 2. Dell Latitude E4310 MiniCard Replacement: adım 4, 3 resimden 3.
    • Pull the white and black antenna cables off of the card.
    • Make note of these connectors (mark with a marker or pen) as they must be the right connectors for the card to work properly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 28
Her zaman: 658
