Ana içeriğe geç
Dell Latitude E5400 Memory Upgrade / Replacement
Neye ihtiyacın var
  1. Dell Latitude E5400 Memory Upgrade / Replacement, Remove battery: adım 1, 1 resimden 1.
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: adım 2, 2 resimden 1. Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: adım 2, 2 resimden 2.
    • Losen all four screws and remove the backpanel.
    • Remove the backpanel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Dell Latitude E5400 Memory Upgrade / Replacement, change/upgrade the memory: adım 3, 1 resimden 1.
    • Now you can upgrade or change the memory.
    • NOTE: If the laptop doesnt boot after the upgrade, make sure the ram is fully inserted. Still doesnt boot? Try another memory stick.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robin Koch
289 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 2,186
