Ana içeriğe geç
Dell Latitude E5410 keyboard Replacement
Neye ihtiyacın var
  1. Dell Latitude E5410 keyboard Replacement, Dell Latitude E5410 keyboard: adım 1, 1 resimden 1.
    • Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
  2. Dell Latitude E5410 keyboard Replacement: adım 2, 1 resimden 1.
    • Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
  3. Dell Latitude E5410 keyboard Replacement: adım 3, 1 resimden 1.
    • Locate two internal screws (pictured) under removed section.
    • Use the Phillips screwdriver to remove both screws.
    • The screw in the middle is 3.85mm and the screw on the left is 8.66mm.
  4. Dell Latitude E5410 keyboard Replacement: adım 4, 1 resimden 1.
    • Firmly grip the upper section of the keyboard.
    • Pull on the keyboard in an upwards motion.
    • The keyboard should be successfully removed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 23
Her zaman: 5,118
