Ana içeriğe geç
Dell Latitude E5410 Screen Replacement
Neye ihtiyacın var
  1. Dell Latitude E5410 Screen Replacement, Dell Latitude E5410 Screen Replacement: adım 1, 1 resimden 1.
    • Have your laptop ready with your screen pulled all they way down parallel to the bottom of the laptop.
  2. Dell Latitude E5410 Screen Replacement: adım 2, 1 resimden 1.
    • Start on the top left or right corner of the screen edge and unscrew the small screws.
    • Be sure to remove the rubber placeholders in order to access the screws.
  3. Dell Latitude E5410 Screen Replacement: adım 3, 2 resimden 1. Dell Latitude E5410 Screen Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, pry the bezel away from the screen.
  4. Dell Latitude E5410 Screen Replacement: adım 4, 2 resimden 1. Dell Latitude E5410 Screen Replacement: adım 4, 2 resimden 2.
    • Use the Phillips screwdriver to remove the screws from corners around the screen.
  5. Dell Latitude E5410 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the screws from both sides.
    • Once removed, they will release the screen.
  6. Dell Latitude E5410 Screen Replacement: adım 6, 2 resimden 1. Dell Latitude E5410 Screen Replacement: adım 6, 2 resimden 2.
    • Use the spudger to move the sensor aside.
  7. Dell Latitude E5410 Screen Replacement: adım 7, 2 resimden 1. Dell Latitude E5410 Screen Replacement: adım 7, 2 resimden 2.
    • Release the screen by pulling up and out.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 31
Her zaman: 2,760
