Giriş
When a problem exists with the display, wifi, camera, or even the laptop lid itself, it is often easier to just replace the whole screen assembly. This guide is a quick simple way to accomplish this task.
Neye ihtiyacın var
Loosen the 8 Philips screws on the bottom of the laptop. They will not come all the way out but loosen till they spin freely.
Use a splurger to slowly pry the bottom cover off the laptop. Pull the bottom off in the direction of the arrow.
Important Be carefull to not break the snaps as they are delicate.
Important Disconnect the battery before any work is done. Failure to do so could result in electric shock and cause harm to you and the laptop.
Carefully use the plastic tab to remove the battery cable from the motherboard.
Unscrew the screw holding the card in place.
Remove the metal guard holding the connections in place.
Use the splurger to gently lift the wires from the card.
Remove screw holding the metal plate in place.
Remove metal plate
Carefully pull on the tab to disconnect the display cable from the motherboard.
Remove both screws holding the plate in place.
Remove plate
Remove tape holding the display cable to the laptop.
Pull the cable free
Remove both the screws and hing covers on the back of the device.
Remove screws underneath the hinge covers on the back of the device
Carefully remove the display from its slots.
Be mindful to feed the WiFi and Display cables through the holes.
5 farklı kişi bu kılavuzu tamamladı.
