Ana içeriğe geç
Dell Latitude E5500 Bluetooth Card Replacement
Neye ihtiyacın var
  1. Dell Latitude E5500 Bluetooth Card Replacement, Bluetooth Card: adım 1, 1 resimden 1.
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Bluetooth Card Replacement: adım 2, 2 resimden 1. Dell Latitude E5500 Bluetooth Card Replacement: adım 2, 2 resimden 2.
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Bluetooth Card Replacement: adım 3, 2 resimden 1. Dell Latitude E5500 Bluetooth Card Replacement: adım 3, 2 resimden 2.
    • The Bluetooth card is located near the front of the device, and is the expansion card with one antenna attached to it.
  4. Dell Latitude E5500 Bluetooth Card Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the wire connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Bluetooth Card Replacement: adım 5, 1 resimden 1.
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Bluetooth Card Replacement: adım 6, 2 resimden 1. Dell Latitude E5500 Bluetooth Card Replacement: adım 6, 2 resimden 2.
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Richard Harrison
805 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 UMass Dartmouth, Team 2-4, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 2,630
