Ana içeriğe geç
Dell Latitude E5500 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude E5500 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: adım 2, 2 resimden 1. Dell Latitude E5500 RAM Replacement: adım 2, 2 resimden 2.
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: adım 3, 1 resimden 1.
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: adım 4, 2 resimden 1. Dell Latitude E5500 RAM Replacement: adım 4, 2 resimden 2.
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: adım 5, 3 resimden 1. Dell Latitude E5500 RAM Replacement: adım 5, 3 resimden 2. Dell Latitude E5500 RAM Replacement: adım 5, 3 resimden 3.
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
Sonuç
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
Evan Eldridge
215 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 UMass Dartmouth, Team 2-4, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 2,184
