Ana içeriğe geç
Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement
Neye ihtiyacın var
  1. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Remove Battery: adım 1, 2 resimden 1. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Remove Battery: adım 1, 2 resimden 2.
    • Slide the release latches to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: adım 2, 3 resimden 1. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: adım 2, 3 resimden 2. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: adım 2, 3 resimden 3.
    • Pry the top edge of the display bezel.
    • Work your way along to the sides and bottom edge of the display bezel
    • Remove the display bezel from the display assembly
  3. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: adım 3, 3 resimden 1. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: adım 3, 3 resimden 2. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: adım 3, 3 resimden 3.
    • Remove the 6 (M2 x 3mm) screws that secure the display panel to the display assembly
    • Flip the display panel over
    • Peel off the LVDS cable connector tape and disconnect the LVDS cable from the display panel
    • Remove the display panel from the display assembly
Sonuç
alarson118
553 İtibar
3 adet Kılavuz yazıldı
Ekip
Tech-zone Tech-zone üyesi
Business
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 208
