Ana içeriğe geç
Dell Latitude E6330 Hard-Drive Replacement
Neye ihtiyacın var
  1. Dell Latitude E6330 Hard-Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off computer by holding down the power button
  2. Dell Latitude E6330 Hard-Drive Replacement: adım 2, 3 resimden 1. Dell Latitude E6330 Hard-Drive Replacement: adım 2, 3 resimden 2. Dell Latitude E6330 Hard-Drive Replacement: adım 2, 3 resimden 3.
    • Slide latches out to unlock and remove battery.
  3. Dell Latitude E6330 Hard-Drive Replacement, Hard-Drive: adım 3, 1 resimden 1.
    • Flip the laptop over so the bottom face is facing up.
    • Only follow the battery replacement guide up to removal. You do not need to replace the battery as well if you are replacing the hard-drive. Removal is only done to prevent damage to the laptop.
  4. Dell Latitude E6330 Hard-Drive Replacement: adım 4, 1 resimden 1.
    • Using the Phillips #00, remove the two 2.5mm x 5mm screws located at the front left corner of the laptop.
  5. Dell Latitude E6330 Hard-Drive Replacement: adım 5, 1 resimden 1.
    • Slide the hard drive & caddy out of its slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Donahue
130 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Simcock Spring 2019 UMass Dartmouth, Team S2-G3, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 1,413
