Ana içeriğe geç
Dell Latitude E6400 Screen Replacement
Neye ihtiyacın var
  1. Dell Latitude E6400 Screen Replacement, Battery Removal: adım 1, 3 resimden 1. Dell Latitude E6400 Screen Replacement, Battery Removal: adım 1, 3 resimden 2. Dell Latitude E6400 Screen Replacement, Battery Removal: adım 1, 3 resimden 3.
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
  2. Dell Latitude E6400 Screen Replacement, Display Plastic Lids: adım 2, 3 resimden 1. Dell Latitude E6400 Screen Replacement, Display Plastic Lids: adım 2, 3 resimden 2. Dell Latitude E6400 Screen Replacement, Display Plastic Lids: adım 2, 3 resimden 3.
    • Remove the two 4.8mm Phillips screws securing the plastic lids.
    • Slide the plastic lids of the case
  3. Dell Latitude E6400 Screen Replacement, Display Data Cable: adım 3, 2 resimden 1. Dell Latitude E6400 Screen Replacement, Display Data Cable: adım 3, 2 resimden 2.
    • Grab the plastic pull tab secured to the display data cable lock and pull the display data cable connector straight up from its socket.
    • De-route the display data cable from the channel.
  4. Dell Latitude E6400 Screen Replacement, Wi-Fi Antenna Cable: adım 4, 2 resimden 1. Dell Latitude E6400 Screen Replacement, Wi-Fi Antenna Cable: adım 4, 2 resimden 2.
    • Using spudger lift and disconnect Wi-Fi antenna cable.
    • De-route the Wi-Fi antenna cable from it's channel.
  5. Dell Latitude E6400 Screen Replacement, Display Assembly: adım 5, 3 resimden 1. Dell Latitude E6400 Screen Replacement, Display Assembly: adım 5, 3 resimden 2. Dell Latitude E6400 Screen Replacement, Display Assembly: adım 5, 3 resimden 3.
    • Open your laptop so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the two 4.8 mm Phillips screws from the display brackets.
    • Grab the upper case with your right hand and rotate the display slightly away from the upper case. Lift the display away from the upper case, minding any brackets or cables that may get caught.
Sonuç
D. K. Labudek
685 İtibar
4 adet Kılavuz yazıldı
2 Yorum
How to fix the flickering of screen in Dell latitude E6400
Surprisesipho - Yanıt
I would start with resetting the connectors on motherboard side and then on the screen side. Then I would try replacing cables. Anything above that would require multimeter knowledge. Always start from cheapest to more expensive.
D. K. Labudek -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 621
