Ana içeriğe geç
Dell Latitude E6420 CPU Replacement
Neye ihtiyacın var
  1. Dell Latitude E6420 CPU Replacement, Rear Panel Removal: adım 1, 2 resimden 1. Dell Latitude E6420 CPU Replacement, Rear Panel Removal: adım 1, 2 resimden 2.
    • Remove the eight screws holding down the rear panel using a Phillips #0 Screwdriver. Carefully remove base cover by hand.
  2. Dell Latitude E6420 CPU Replacement, CPU: adım 2, 1 resimden 1.
    • Remove the battery by pushing the tabs outward, then removing the battery from the device.
  3. Dell Latitude E6420 CPU Replacement: adım 3, 1 resimden 1.
    • Remove the four screws securing the heatsink using the Phillips #0 screwdriver.
    • Remove the heatsink and fan assembly.
  4. Dell Latitude E6420 CPU Replacement: adım 4, 1 resimden 1.
    • Use the flat end of a spudger to rotate the lock 180 degrees counterclockwise to unlock the CPU.
  5. Dell Latitude E6420 CPU Replacement: adım 5, 2 resimden 1. Dell Latitude E6420 CPU Replacement: adım 5, 2 resimden 2.
    • Lift the CPU out of the motherboard assembly.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 44
Her zaman: 3,680
