Ana içeriğe geç
Dell Latitude E6420 Fan Replacement
Neye ihtiyacın var
  1. Dell Latitude E6420 Fan Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude E6420 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Fan Replacement: adım 2, 1 resimden 1.
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Fan Replacement, CD/DVD Drive: adım 3, 2 resimden 1. Dell Latitude E6420 Fan Replacement, CD/DVD Drive: adım 3, 2 resimden 2.
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Fan Replacement: adım 4, 2 resimden 1. Dell Latitude E6420 Fan Replacement: adım 4, 2 resimden 2.
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Fan Replacement, Backplate: adım 5, 2 resimden 1. Dell Latitude E6420 Fan Replacement, Backplate: adım 5, 2 resimden 2.
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Fan Replacement: adım 6, 2 resimden 1. Dell Latitude E6420 Fan Replacement: adım 6, 2 resimden 2.
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Fan Replacement, Fan: adım 7, 2 resimden 1. Dell Latitude E6420 Fan Replacement, Fan: adım 7, 2 resimden 2.
    • Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
  8. Dell Latitude E6420 Fan Replacement: adım 8, 2 resimden 1. Dell Latitude E6420 Fan Replacement: adım 8, 2 resimden 2.
    • Use the plastic opening tool to unclip the connector.
  9. Dell Latitude E6420 Fan Replacement: adım 9, 1 resimden 1.
    • Lift the fan out of the laptop.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Madysen Eames
1.555 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 UMass Dartmouth, Team S2-G3, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G3
3 Üyeler
1Rehber Yorum
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
Godwin Nwachukwu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 2,330
