Ana içeriğe geç
Dell Latitude E6420 Screen Replacement
Neye ihtiyacın var
  1. Dell Latitude E6420 Screen Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude E6420 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Screen Replacement: adım 2, 1 resimden 1.
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Screen Replacement, Screen: adım 3, 2 resimden 1. Dell Latitude E6420 Screen Replacement, Screen: adım 3, 2 resimden 2.
    • Open the laptop and lay it flat on your work surface.
    • Using the spudger, lift the bezel up from around the laptop screen.
  4. Dell Latitude E6420 Screen Replacement: adım 4, 3 resimden 1. Dell Latitude E6420 Screen Replacement: adım 4, 3 resimden 2. Dell Latitude E6420 Screen Replacement: adım 4, 3 resimden 3.
    • Using the screwdriver, remove four 5mm Phillips #0 screws from the bottom of the laptop screen.
    • Using the screwdriver, remove two 3mm Phillips #0 screws from the top of the laptop screen.
    • Lift the screen.
  5. Dell Latitude E6420 Screen Replacement: adım 5, 1 resimden 1.
    • Lift the laptop screen and flip it over to lay it on top of the keyboard.
  6. Dell Latitude E6420 Screen Replacement: adım 6, 2 resimden 1. Dell Latitude E6420 Screen Replacement: adım 6, 2 resimden 2.
    • Remove the piece of tape from the back of the LCD cable.
  7. Dell Latitude E6420 Screen Replacement: adım 7, 2 resimden 1. Dell Latitude E6420 Screen Replacement: adım 7, 2 resimden 2.
    • Lift the piece of tape attached to the LCD cable.
    • Once the tape has lifted, gently pull back to unplug the LCD cable.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Madysen Eames
1.555 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 UMass Dartmouth, Team S2-G3, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G3
3 Üyeler
1Rehber Yorum
Bonjour, Merci
endibos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 30
Her zaman: 4,212
