Ana içeriğe geç
Dell Latitude E6440 Memory Replacement
Neye ihtiyacın var
      • Make sure all external components are removed from the device( ie. USBs, power cords, network cables, headphones, etc.) and the device is powered off.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Latitude E6440 Memory  Replacement, Remove Battery: adım 2, 3 resimden 1. Dell Latitude E6440 Memory  Replacement, Remove Battery: adım 2, 3 resimden 2. Dell Latitude E6440 Memory  Replacement, Remove Battery: adım 2, 3 resimden 3.
      • Slide the battery release latches into the unlock position. Then, rotate the outer edge of the battery upward and remove from the system.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Latitude E6440 Memory  Replacement, Remove base cover: adım 3, 2 resimden 1. Dell Latitude E6440 Memory  Replacement, Remove base cover: adım 3, 2 resimden 2.
      • After removing the battery, remove the screws that secure the base cover to the computer, then lift the base cover and remove it from the computer.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude E6440 Memory  Replacement, Remove memory: adım 4, 2 resimden 1. Dell Latitude E6440 Memory  Replacement, Remove memory: adım 4, 2 resimden 2.
      • Pry the securing clips away from the memory module until it pops-up and remove the memory module from its connector on the system board.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Latitude E6440 Memory  Replacement, Install new memory: adım 5, 2 resimden 1. Dell Latitude E6440 Memory  Replacement, Install new memory: adım 5, 2 resimden 2.
      • With your new memory, insert the memory into the memory socket, then press the securing clips to secure the memory module to the system board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Reassemble your device by performing the instructions above in reverse order.
Bir başkası bu kılavuzu tamamladı.
Aaron Thomas
1.314 İtibar
10 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
12.274 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 1,033
