Ana içeriğe geç
Dell Latitude E6510 Heat Sink Replacement
Neye ihtiyacın var
  1. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: adım 1, 3 resimden 1. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: adım 1, 3 resimden 2. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: adım 1, 3 resimden 3.
    • Locate the tabs that lock the battery in place.
    • Push tabs towards each other while simultaneously pushing the battery away from the device.
  2. Dell Latitude E6510  Heat Sink Replacement: adım 2, 3 resimden 1. Dell Latitude E6510  Heat Sink Replacement: adım 2, 3 resimden 2. Dell Latitude E6510  Heat Sink Replacement: adım 2, 3 resimden 3.
    • Unscrew the screw located in the center of the back panel. Do not completely remove the screw, a spring will keep it in place when it has been loosened.
    • Slide the panel back until it unlocks.
  3. Dell Latitude E6510  Heat Sink Replacement: adım 3, 3 resimden 1. Dell Latitude E6510  Heat Sink Replacement: adım 3, 3 resimden 2. Dell Latitude E6510  Heat Sink Replacement: adım 3, 3 resimden 3.
    • Locate the fan plug.
    • Pull up until it is unplugged from the reciever.
    • Take caution when unplugging the fan plug from the receiver.
  4. Dell Latitude E6510  Heat Sink Replacement: adım 4, 3 resimden 1. Dell Latitude E6510  Heat Sink Replacement: adım 4, 3 resimden 2. Dell Latitude E6510  Heat Sink Replacement: adım 4, 3 resimden 3.
    • Unscrew the two 5.5 mm screws securing the fan.
    • Lift the end of the fan opposite the copper wire up.
    • Pull the fan away from the device.
  5. Dell Latitude E6510  Heat Sink Replacement: adım 5, 1 resimden 1.
    • Locate and loosen the four silver screws holding down the heat redistribute component.
    • Do not competely remove the screws as springs keep the screws attached to the metal plate after you loosen them.
  6. Dell Latitude E6510  Heat Sink Replacement: adım 6, 3 resimden 1. Dell Latitude E6510  Heat Sink Replacement: adım 6, 3 resimden 2. Dell Latitude E6510  Heat Sink Replacement: adım 6, 3 resimden 3.
    • Lift the metal plate up on the end closest to the screws.
    • Slide the whole assembly away from where you removed the fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 43
Her zaman: 1,050
