Ana içeriğe geç
Dell Latitude E6510 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude E6510 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Use a J1 screwdriver to remove the 8mm screw on the bottom cover.
  2. Dell Latitude E6510 RAM Replacement: adım 2, 1 resimden 1.
    • Unclasp and pull the memory card up.
    • Be careful when unclasping and releasing the memory card. Clasps are fragile.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kolin Doyle
500 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S8-G4, Johnson Fall 2017 Baylor, Team S8-G4, Johnson Fall 2017 üyesi
BU-JOHNSON-F17S8G4
1 Üye
Bir Yorum
There should be four steps to this, step two should be removing the 4 hard drive screws,
step three should be removing the bottom cover, including that it slides off, as many bottom covers snap in.
I almost damaged the bottom cover trying to pry it up.
Brian Barlow - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 2,087
