Ana içeriğe geç
Dell Latitude E6510 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude E6510 RAM Replacement, RAM: adım 1, 3 resimden 1. Dell Latitude E6510 RAM Replacement, RAM: adım 1, 3 resimden 2. Dell Latitude E6510 RAM Replacement, RAM: adım 1, 3 resimden 3.
    • Orient the laptop so that the bottom is facing up towards you.
    • Place your thumbs on the grooved sections above the battery and firmly pull away from each other.
    • Slide the battery out and separate it from the laptop.
  2. Dell Latitude E6510 RAM Replacement: adım 2, 3 resimden 1. Dell Latitude E6510 RAM Replacement: adım 2, 3 resimden 2. Dell Latitude E6510 RAM Replacement: adım 2, 3 resimden 3.
    • Remove the 5 screws from the back panel with a type 0 Phillips head.
    • Pull the panel towards you in a slightly upwards motion.
    • Remove the panel from the laptop and set it aside.
  3. Dell Latitude E6510 RAM Replacement: adım 3, 3 resimden 1. Dell Latitude E6510 RAM Replacement: adım 3, 3 resimden 2. Dell Latitude E6510 RAM Replacement: adım 3, 3 resimden 3.
    • Locate the RAM sticks in the laptop.
    • Using your fingers, disconnect the prongs connected to the RAM sticks.
    • Gently remove the RAM from the port.
    • Repeat the first three steps to remove the second RAM stick.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 287
