Ana içeriğe geç
Dell Latitude E6520 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Latitude E6520 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude E6520 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 Keyboard Replacement: adım 2, 2 resimden 1. Dell Latitude E6520 Keyboard Replacement: adım 2, 2 resimden 2.
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 Keyboard Replacement, Bottom Cover: adım 3, 2 resimden 1. Dell Latitude E6520 Keyboard Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Remove the ten 8.6 mm JIS #0 screws.
  4. Dell Latitude E6520 Keyboard Replacement: adım 4, 1 resimden 1.
    • Place fingers underneath cover and pull off the cover.
  5. Dell Latitude E6520 Keyboard Replacement, Keyboard: adım 5, 3 resimden 1. Dell Latitude E6520 Keyboard Replacement, Keyboard: adım 5, 3 resimden 2. Dell Latitude E6520 Keyboard Replacement, Keyboard: adım 5, 3 resimden 3.
    • Pry off the plastic keyboard trim. It is easiest to start at the bottom of the keyboard.
  6. Dell Latitude E6520 Keyboard Replacement: adım 6, 2 resimden 1. Dell Latitude E6520 Keyboard Replacement: adım 6, 2 resimden 2.
    • Remove the six 3.63 mm JIS #0 screws holding the keyboard in place.
  7. Dell Latitude E6520 Keyboard Replacement: adım 7, 2 resimden 1. Dell Latitude E6520 Keyboard Replacement: adım 7, 2 resimden 2.
    • Lift the keypad up from the bottom.
    • Rest the keypad on the LCD screen for easy access during the next step.
  8. Dell Latitude E6520 Keyboard Replacement: adım 8, 2 resimden 1. Dell Latitude E6520 Keyboard Replacement: adım 8, 2 resimden 2.
    • Peel back the tape holding the ribbon connector.
    • Disconnect the ribbon and the keyboard will be free from the laptop.
Sonuç
Alec Weiss
800 İtibar
8 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Baechle Fall 2018 IUPUI, Team S2-G2, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S2G2
3 Üyeler
Bir Yorum
Hello,
Nice instructions, could someone please tell me what are the other conector/ribbions used for in this dell e6520 under the keyboard ? any help will most appreciated.
Thanks in advance
khalidaafghany - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,812
