Ana içeriğe geç
Dell Latitude E6520 LCD Screen Replacement
Neye ihtiyacın var
  1. Dell Latitude E6520 LCD Screen Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude E6520 LCD Screen Replacement, Battery: adım 1, 2 resimden 2.
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 LCD Screen Replacement: adım 2, 2 resimden 1. Dell Latitude E6520 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 LCD Screen Replacement, LCD Screen: adım 3, 1 resimden 1.
    • Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
  4. Dell Latitude E6520 LCD Screen Replacement: adım 4, 2 resimden 1. Dell Latitude E6520 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Remove the six 5.75 mm JIS #0 screws that hold the LCD screen to the cover.
  5. Dell Latitude E6520 LCD Screen Replacement: adım 5, 2 resimden 1. Dell Latitude E6520 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Once all the screws have been removed, lay the screen down on the keyboard and disconnect the LCD cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alec Weiss
800 İtibar
8 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Baechle Fall 2018 IUPUI, Team S2-G2, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S2G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 1,283
