Ana içeriğe geç
Dell Latitude E6520 WLAN Adaptor Card Replacement
Neye ihtiyacın var
  1. Dell Latitude E6520 WLAN Adaptor Card Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude E6520 WLAN Adaptor Card Replacement, Battery: adım 1, 2 resimden 2.
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 WLAN Adaptor Card Replacement: adım 2, 2 resimden 1. Dell Latitude E6520 WLAN Adaptor Card Replacement: adım 2, 2 resimden 2.
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 WLAN Adaptor Card Replacement, Bottom Cover: adım 3, 2 resimden 1. Dell Latitude E6520 WLAN Adaptor Card Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Remove the ten 8.6 mm JIS #0 screws.
  4. Dell Latitude E6520 WLAN Adaptor Card Replacement: adım 4, 1 resimden 1.
    • Place fingers underneath cover and pull off the cover.
  5. Dell Latitude E6520 WLAN Adaptor Card Replacement, WLAN Adapter Card: adım 5, 1 resimden 1.
    • Gently pull the two wires connected to the WLAN Adapter Card.
  6. Dell Latitude E6520 WLAN Adaptor Card Replacement: adım 6, 2 resimden 1. Dell Latitude E6520 WLAN Adaptor Card Replacement: adım 6, 2 resimden 2.
    • Remove the two electrode connectors.
    • Remove the single 3.67 mm JIS #0 screw that holds the WLAN Adapter Card to the laptop.
    • The WLAN Adapter Card will pop up once the screws are taken out.
  7. Dell Latitude E6520 WLAN Adaptor Card Replacement: adım 7, 2 resimden 1. Dell Latitude E6520 WLAN Adaptor Card Replacement: adım 7, 2 resimden 2.
    • Pull WLAN Adapter Card to remove it from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alec Weiss
800 İtibar
8 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Baechle Fall 2018 IUPUI, Team S2-G2, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S2G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 936
