Ana içeriğe geç
Dell Latitude E6530 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Latitude E6530 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the computer over so that the bottom panel is facing you.
  2. Dell Latitude E6530 Hard Drive Replacement: adım 2, 2 resimden 1. Dell Latitude E6530 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the switches away from each other to release the battery.
  3. Dell Latitude E6530 Hard Drive Replacement: adım 3, 2 resimden 1. Dell Latitude E6530 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using your hands, gently remove the battery from the device.
  4. Dell Latitude E6530 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Dell Latitude E6530 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver, unscrew the two screws.
  5. Dell Latitude E6530 Hard Drive Replacement: adım 5, 2 resimden 1. Dell Latitude E6530 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Gently remove the hard drive.
  6. Dell Latitude E6530 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Undo the Phillips #1 screw keeping the drive in the bracket.
  7. Dell Latitude E6530 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove the drive from the bracket,
Sonuç
To reassemble your device, follow these instructions in reverse order. Refer to the troubleshooting guide and additional links for more information if issue persists.
Bir Yorum
There’s a missing step here. There’s another screw you’re supposed to undo to remove the drive.
Ella - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 877
