Ana içeriğe geç
Dell Latitude E6530 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Latitude E6530 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Pull back the 2 battery tabs.
  2. Dell Latitude E6530 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pull out the battery.
  3. Dell Latitude E6530 Motherboard Replacement, DVD Drive: adım 3, 1 resimden 1.
    • Push the button next to the DVD drive.
  4. Dell Latitude E6530 Motherboard Replacement: adım 4, 1 resimden 1.
    • Pull out the DVD Drive.
  5. Dell Latitude E6530 Motherboard Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Undo the 2 Phillips #00 screws.
  6. Dell Latitude E6530 Motherboard Replacement: adım 6, 1 resimden 1.
    • Pull out the hard drive.
  7. Dell Latitude E6530 Motherboard Replacement, Back Cover: adım 7, 1 resimden 1.
    • Remove the 5 Phillips #00 screws.
  8. Dell Latitude E6530 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the back cover.
  9. Dell Latitude E6530 Motherboard Replacement, Keyboard: adım 9, 2 resimden 1. Dell Latitude E6530 Motherboard Replacement, Keyboard: adım 9, 2 resimden 2.
    • Flip over and open the laptop.
  10. Dell Latitude E6530 Motherboard Replacement: adım 10, 3 resimden 1. Dell Latitude E6530 Motherboard Replacement: adım 10, 3 resimden 2. Dell Latitude E6530 Motherboard Replacement: adım 10, 3 resimden 3.
    • Use your fingernail or opening tool to remove the keyboard bezel.
  11. Dell Latitude E6530 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the 3 Phillips #00 screws.
  12. Dell Latitude E6530 Motherboard Replacement: adım 12, 1 resimden 1.
    • Carefully remove the keyboard.
    • Do not lift up the keyboard too much, as it is still attached via a ribbon cable.
  13. Dell Latitude E6530 Motherboard Replacement: adım 13, 2 resimden 1. Dell Latitude E6530 Motherboard Replacement: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingernail to lift up the ribbon cable lock.
    • Use a pair of tweezers or your finger to remove the keyboard ribbon cable
    • Set the keyboard aside.
  14. Dell Latitude E6530 Motherboard Replacement, Palmrest: adım 14, 1 resimden 1.
    • Remove the 10 Phillips #00 screws.
  15. Dell Latitude E6530 Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the 8 Phillips #00 screws,
  16. Dell Latitude E6530 Motherboard Replacement: adım 16, 1 resimden 1.
    • Use a pair of tweezers to remove the trackpad ribbon cable.
  17. Dell Latitude E6530 Motherboard Replacement: adım 17, 1 resimden 1.
    • Use a pair of tweezers to remove the ribbon cable for the lights and buttons.
  18. Dell Latitude E6530 Motherboard Replacement: adım 18, 1 resimden 1.
    • Lift off the laptop's palmrest.
  19. Dell Latitude E6530 Motherboard Replacement, Wi-Fi and cellular cards: adım 19, 2 resimden 1. Dell Latitude E6530 Motherboard Replacement, Wi-Fi and cellular cards: adım 19, 2 resimden 2.
    • Close and flip over the laptop.
    • Remove the antenna cables and screws from the Wi-Fi card and the cellular card.
  20. Dell Latitude E6530 Motherboard Replacement: adım 20, 2 resimden 1. Dell Latitude E6530 Motherboard Replacement: adım 20, 2 resimden 2.
    • Remove the Wi-Fi and cellular cards.
  21. Dell Latitude E6530 Motherboard Replacement, CMOS battery: adım 21, 1 resimden 1.
    • Disconnect and remove the CMOS battery.
  22. Dell Latitude E6530 Motherboard Replacement, Heatsink: adım 22, 1 resimden 1.
    • Remove the 4 heatsink screws.
  23. Dell Latitude E6530 Motherboard Replacement: adım 23, 2 resimden 1. Dell Latitude E6530 Motherboard Replacement: adım 23, 2 resimden 2.
    • Disconnect and remove the heatsink.
    • Make sure you have thermal paste before doing this! You will need to reapply the CPU's thermal paste.
  24. Dell Latitude E6530 Motherboard Replacement, CPU: adım 24, 1 resimden 1.
    • Use a knife or flathead screwdriver to turn the CPU lock counter-clockwise.
    • Remember to turn the CPU lock clockwise when reassembling the laptop! If you don't, the system will not turn on.
  25. Dell Latitude E6530 Motherboard Replacement: adım 25, 1 resimden 1.
    • Remove the CPU
    • Be VERY CAREFUL to not bend ANY pins on the CPU.
  26. Dell Latitude E6530 Motherboard Replacement, Display Cable: adım 26, 2 resimden 1. Dell Latitude E6530 Motherboard Replacement, Display Cable: adım 26, 2 resimden 2.
    • Unscrew and remove the bracket.
  27. Dell Latitude E6530 Motherboard Replacement: adım 27, 2 resimden 1. Dell Latitude E6530 Motherboard Replacement: adım 27, 2 resimden 2.
    • Disconnect the display cables.
  28. Dell Latitude E6530 Motherboard Replacement, Motherboard: adım 28, 3 resimden 1. Dell Latitude E6530 Motherboard Replacement, Motherboard: adım 28, 3 resimden 2. Dell Latitude E6530 Motherboard Replacement, Motherboard: adım 28, 3 resimden 3.
    • Remove the 2 motherboard cables.
  29. Dell Latitude E6530 Motherboard Replacement: adım 29, 1 resimden 1.
    • Remove the 5 motherboard screws.
  30. Dell Latitude E6530 Motherboard Replacement: adım 30, 2 resimden 1. Dell Latitude E6530 Motherboard Replacement: adım 30, 2 resimden 2.
    • Remove the 2 bracket screws.
    • Remove the bracket.
  31. Dell Latitude E6530 Motherboard Replacement: adım 31, 1 resimden 1.
    • Remove the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ella
2.221 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 836
