Ana içeriğe geç
Dell Latitude E6540 Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude E6540 Battery Replacement, Hibernate your laptop: adım 1, 2 resimden 1. Dell Latitude E6540 Battery Replacement, Hibernate your laptop: adım 1, 2 resimden 2.
    • It is possible to plug the laptop in to avoid hibernating the system.
    • Locate the Hibernate option in the Start menu. Let the system fully hibernate (or shut down) before removing the battery.
  2. Dell Latitude E6540 Battery Replacement, Unlock the battery: adım 2, 2 resimden 1. Dell Latitude E6540 Battery Replacement, Unlock the battery: adım 2, 2 resimden 2.
    • Flip the laptop over and unlock the 2 battery tabs. The tabs will remain unlocked until the battery is removed.
  3. Dell Latitude E6540 Battery Replacement, Remove the old battery: adım 3, 3 resimden 1. Dell Latitude E6540 Battery Replacement, Remove the old battery: adım 3, 3 resimden 2. Dell Latitude E6540 Battery Replacement, Remove the old battery: adım 3, 3 resimden 3.
    • The "extended runtime" battery on this model will stick out a few inches by design. This cannot be avoided.
    • Remove the battery. Pull the battery up from the back.
  4. Dell Latitude E6540 Battery Replacement, Install the new battery: adım 4, 3 resimden 1. Dell Latitude E6540 Battery Replacement, Install the new battery: adım 4, 3 resimden 2. Dell Latitude E6540 Battery Replacement, Install the new battery: adım 4, 3 resimden 3.
    • This step does not apply if this guide is being used as a prerequisite.
    • Align the battery with the tabs on the chassis. Drop the battery in place once lined up. If needed, use light pressure to seat it in the computer.
  5. Dell Latitude E6540 Battery Replacement, Plug your laptop in: adım 5, 1 resimden 1.
    • Turn the computer on and plug the charger in.
Bitiş Çizgisi
7 farklı kişi bu kılavuzu tamamladı.
Nick
93.519 İtibar
59 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.699 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 8,486
