Ana içeriğe geç
Dell Latitude E6540 Thermal paste Replacement
Neye ihtiyacın var
  1. Dell Latitude E6540 Thermal paste Replacement, Thermal paste: adım 1, 2 resimden 1. Dell Latitude E6540 Thermal paste Replacement, Thermal paste: adım 1, 2 resimden 2.
    • First remove the 3 screws to remove the lead
  2. Dell Latitude E6540 Thermal paste Replacement: adım 2, 1 resimden 1.
    • Then remove those 7 screws in order and try to keep track of which each screw place for when you assemble it back
  3. Dell Latitude E6540 Thermal paste Replacement: adım 3, 1 resimden 1.
    • Carefully remove the fan connector
  4. Dell Latitude E6540 Thermal paste Replacement: adım 4, 1 resimden 1.
    • carefully shake the heatsink until the thermal past loosens and it moves freely
  5. Dell Latitude E6540 Thermal paste Replacement: adım 5, 1 resimden 1.
    • Now pull down the heat sink from its place
  6. Dell Latitude E6540 Thermal paste Replacement: adım 6, 1 resimden 1.
    • Clean off the old thermal paste from the heat sink, CPU, and GPU, and then apply the new thermal paste
  7. Dell Latitude E6540 Thermal paste Replacement: adım 7, 1 resimden 1.
    • put everything back into place, and don't forget to attack the connector to its place, and with that you are done
Sonuç
Hunter
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 67
