Ana içeriğe geç
Dell Latitude E7250 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude E7250 RAM Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude E7250 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 RAM Replacement, RAM: adım 2, 3 resimden 1. Dell Latitude E7250 RAM Replacement, RAM: adım 2, 3 resimden 2. Dell Latitude E7250 RAM Replacement, RAM: adım 2, 3 resimden 3.
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 RAM Replacement: adım 3, 3 resimden 1. Dell Latitude E7250 RAM Replacement: adım 3, 3 resimden 2. Dell Latitude E7250 RAM Replacement: adım 3, 3 resimden 3.
    • The RAM stick will be located on the left side of the computer.
    • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
    • Pull the RAM stick gently, at an angle away from the rest of the computer.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 51
Her zaman: 4,866
