Ana içeriğe geç
Dell Latitude E7250 SSD Replacement
Neye ihtiyacın var
  1. Dell Latitude E7250 SSD Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude E7250 SSD Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 SSD Replacement, SSD: adım 2, 3 resimden 1. Dell Latitude E7250 SSD Replacement, SSD: adım 2, 3 resimden 2. Dell Latitude E7250 SSD Replacement, SSD: adım 2, 3 resimden 3.
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 SSD Replacement: adım 3, 3 resimden 1. Dell Latitude E7250 SSD Replacement: adım 3, 3 resimden 2. Dell Latitude E7250 SSD Replacement: adım 3, 3 resimden 3.
    • Locate your SSD, it is on the right side and held in with a small screw.
    • Unscrew the SSD carefully. Once done, the SSD will "pop" upwards at an angle making removal easy.
    • Gently grasp the SSD on either side with your thumb and forefinger and pull away from the computer.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks a lot for this !
viperx007 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 37
Son 30 gün: 145
Her zaman: 10,832
