Ana içeriğe geç
Dell Latitude E7270 Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude E7270 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Battery Replacement: adım 2, 1 resimden 1.
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Battery Replacement: adım 3, 1 resimden 1.
    • Lift and remove the panel.
  4. Dell Latitude E7270 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
On Step 4 there is no screw on middle since that hole is for backpanel center screw.
Mikko Kuusio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 72
Her zaman: 3,475
