Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Place the device top down in front of you so that the vents are visible and are furthest from the user.
Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
Remove the battery completely by grabbing an edge and pulling up on the battery.
Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
Lift and remove fan by pulling gently straight up using your fingers
Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
