Ana içeriğe geç
Dell Latitude E7270 Motherboard Removal
Neye ihtiyacın var
  1. Dell Latitude E7270 Motherboard Removal, Back Panel: adım 1, 1 resimden 1.
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Motherboard Removal: adım 2, 1 resimden 1.
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Motherboard Removal: adım 3, 1 resimden 1.
    • Lift and remove the panel.
  4. Dell Latitude E7270 Motherboard Removal, Battery: adım 4, 1 resimden 1.
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Motherboard Removal: adım 5, 1 resimden 1.
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Motherboard Removal: adım 6, 1 resimden 1.
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Motherboard Removal, Cooling Fan: adım 7, 3 resimden 1. Dell Latitude E7270 Motherboard Removal, Cooling Fan: adım 7, 3 resimden 2. Dell Latitude E7270 Motherboard Removal, Cooling Fan: adım 7, 3 resimden 3.
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Motherboard Removal: adım 8, 1 resimden 1.
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Motherboard Removal: adım 9, 1 resimden 1.
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
  10. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: adım 10, 3 resimden 1. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: adım 10, 3 resimden 2. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: adım 10, 3 resimden 3.
    • Remove the 10 wire connections by using your fingers to separate the connections.
    • Remove the thirteen M2.5 X 5MM screws that fasten the motherboard using a Phillips #00 screwdriver.
    • Remove the two M2.5 X 8MM external screws that fasten the motherboard from outside using a Phillips #00 screwdriver.
  11. Dell Latitude E7270 Motherboard Removal: adım 11, 1 resimden 1.
    • Lift and remove the motherboard by grabbing the outside edges and pulling straight up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 2,686
