Giriş
Use this guide to replace broken RAM modules on your Dell Latitude E7270.
The ram modules are used throughout all processes when active. They do not require a lot of power so they primarily fail due to onboard shorts or physically get damaged. Broken RAM modules can render your computer extremely slow or useless.
Before using this guide, check out the troubleshooting page to see if your symptoms match any that represent bad RAM modules.
You can also use this guide to upgrade your RAM for more a higher memory configuration.
This replacement requires a #00 Phillips head screwdriver.
NOTE: This guide requires removal of the back panel and battery. The extra prerequisite guide steps are included in this guide.
Neye ihtiyacın var
Place the device top down in front of you so that the vents are visible and are furthest from the user.
Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
