Ana içeriğe geç
Dell Latitude E7270 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude E7270 RAM Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 RAM Replacement: adım 2, 1 resimden 1.
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 RAM Replacement: adım 3, 1 resimden 1.
    • Lift and remove the panel.
  4. Dell Latitude E7270 RAM Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 RAM Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 RAM Replacement: adım 6, 1 resimden 1.
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 RAM Replacement, RAM: adım 7, 1 resimden 1.
    • Locate the 2 RAM modules above where the battery would be.
    • The two blue RAM modules used in the photo may vary in color from your device.
  8. Dell Latitude E7270 RAM Replacement: adım 8, 1 resimden 1.
    • While the RAM is still seated, push the silvered clips either side of each stick outwards. There should be some obvious upward movement from each stick.
  9. Dell Latitude E7270 RAM Replacement: adım 9, 1 resimden 1.
    • Firmly grab each RAM with your fingers and pull them away from you to remove them.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 889
