Ana içeriğe geç
Dell Latitude E7440 CMOS Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude E7440 CMOS Battery Replacement, Prepare the laptop: adım 1, 1 resimden 1.
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: adım 2, 3 resimden 1. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: adım 2, 3 resimden 2. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: adım 2, 3 resimden 3.
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 CMOS Battery Replacement, Remove the battery: adım 3, 1 resimden 1.
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: adım 4, 2 resimden 1. Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: adım 4, 2 resimden 2.
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 CMOS Battery Replacement: adım 5, 2 resimden 1. Dell Latitude E7440 CMOS Battery Replacement: adım 5, 2 resimden 2.
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 CMOS Battery Replacement: adım 6, 3 resimden 1. Dell Latitude E7440 CMOS Battery Replacement: adım 6, 3 resimden 2. Dell Latitude E7440 CMOS Battery Replacement: adım 6, 3 resimden 3.
    • Position your nylon spudger on the edge of the white connector, in between the connector and the port.
    • Pull back on the connector until the plastic head disconnects from the port on the laptop body.
    • If the connector is stuck, move the broader end of the spudger back and forth across the connector to slowly loosen the connection.
  7. Dell Latitude E7440 CMOS Battery Replacement: adım 7, 1 resimden 1.
    • Separate the wrapped battery stack from the body by pulling up the wire.
    • You may need to use the flat end of the nylon spudger to separate the battery.
    • The stack is attached using glue, so you might hear a pop when removing it.
    • Reapplying an adhesive to the bottom of the battery is recommended, although not necessary, to keep it in place.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Akash Kedia
1.397 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S2G5
4 Üyeler
2 Yorum
You list no part number for the replacement battery. Do we know the part number? I looked on Dell's website and find nothing. Otherwise, nice write-up!
jess13j - Yanıt
@jess13j, battery is a CR2032 coin cell.
senzog - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 23
Son 30 gün: 104
Her zaman: 13,312
