Ana içeriğe geç
Dell Latitude E7440 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude E7440 RAM Replacement, Prepare the laptop: adım 1, 1 resimden 1.
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 RAM Replacement, Release the battery: adım 2, 3 resimden 1. Dell Latitude E7440 RAM Replacement, Release the battery: adım 2, 3 resimden 2. Dell Latitude E7440 RAM Replacement, Release the battery: adım 2, 3 resimden 3.
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 RAM Replacement, Remove the battery: adım 3, 1 resimden 1.
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 RAM Replacement, RAM: adım 4, 2 resimden 1. Dell Latitude E7440 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 RAM Replacement: adım 5, 2 resimden 1. Dell Latitude E7440 RAM Replacement: adım 5, 2 resimden 2.
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 RAM Replacement: adım 6, 3 resimden 1. Dell Latitude E7440 RAM Replacement: adım 6, 3 resimden 2. Dell Latitude E7440 RAM Replacement: adım 6, 3 resimden 3.
    • For each RAM module, pull apart both the clips and remove the memory.
    • iFixit’s device came without RAM installed. Your device will have a module between each set of clips.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Akash Kedia
1.397 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S2G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 59
Her zaman: 2,607
