Ana içeriğe geç
Dell Latitude E7440 Trackpad Replacement
Neye ihtiyacın var
  1. Dell Latitude E7440 Trackpad Replacement, Trackpad: adım 1, 2 resimden 1. Dell Latitude E7440 Trackpad Replacement, Trackpad: adım 1, 2 resimden 2.
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Trackpad Replacement: adım 2, 3 resimden 1. Dell Latitude E7440 Trackpad Replacement: adım 2, 3 resimden 2. Dell Latitude E7440 Trackpad Replacement: adım 2, 3 resimden 3.
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide access door down and remove it by slightly jerking it. Make sure no part of the door is sticking to the components.
  3. Dell Latitude E7440 Trackpad Replacement: adım 3, 3 resimden 1. Dell Latitude E7440 Trackpad Replacement: adım 3, 3 resimden 2. Dell Latitude E7440 Trackpad Replacement: adım 3, 3 resimden 3.
    • Remove two 5mm screws using the Phillips #0 screwdriver.
    • Unplug highlighted cable. Be careful not to snap it in half.
  4. Dell Latitude E7440 Trackpad Replacement: adım 4, 1 resimden 1.
    • Remove the fan from the device.
  5. Dell Latitude E7440 Trackpad Replacement: adım 5, 3 resimden 1. Dell Latitude E7440 Trackpad Replacement: adım 5, 3 resimden 2. Dell Latitude E7440 Trackpad Replacement: adım 5, 3 resimden 3.
    • Remove cables on the bottom.
  6. Dell Latitude E7440 Trackpad Replacement: adım 6, 3 resimden 1. Dell Latitude E7440 Trackpad Replacement: adım 6, 3 resimden 2. Dell Latitude E7440 Trackpad Replacement: adım 6, 3 resimden 3.
    • Remove the following screws using the Phillips #0 screwdriver.
    • Five 5mm screws.
    • Seven 3mm screws.
    • One 8mm screw.
  7. Dell Latitude E7440 Trackpad Replacement: adım 7, 1 resimden 1.
    • Remove the keyboard bezel. This might take some effort. Use some force in one direction only.
  8. Dell Latitude E7440 Trackpad Replacement: adım 8, 2 resimden 1. Dell Latitude E7440 Trackpad Replacement: adım 8, 2 resimden 2.
    • Remove the two 2.5mm mouse button screws using the Phillips #0 screwdriver.
    • Remove the mouse button.
  9. Dell Latitude E7440 Trackpad Replacement: adım 9, 3 resimden 1. Dell Latitude E7440 Trackpad Replacement: adım 9, 3 resimden 2. Dell Latitude E7440 Trackpad Replacement: adım 9, 3 resimden 3.
    • Remove three 3mm screws using the Phillips #0 screwdriver.
    • Remove the keyboard by pulling it in one direction.
  10. Dell Latitude E7440 Trackpad Replacement: adım 10, 3 resimden 1. Dell Latitude E7440 Trackpad Replacement: adım 10, 3 resimden 2. Dell Latitude E7440 Trackpad Replacement: adım 10, 3 resimden 3.
    • Disconnect the cables from the device.
    • Remove a single 5mm screw using the Phillips #0 screwdriver.
    • Remove the trackpad panel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sheetal Prasanna
649 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Stella Fall 2019 IUPUI, Team S1-G1, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S1G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 2,827
